- Mon Dec 22, 2008 6:07 pm
#84994
any diy on replacing the oem front brakes?
1. car on jackstands.
2. remove wheels.
3. unbolt the brake line brackets from the arm.
4. unbolt the caliper from the back (2 bolts).
5. support the caliper (don't let it hang & put weight on the brake line)
6. unscrew or drill out the 2 screws holding the rotor on.
7. remove rotor & replace with new. no need to put the 2 screws back on.
8. use a big C clamp & compress the pads back in the caliper as far as they will go.
9. pull out old brake pads from caliper
10. put some of that anti squeak gel on the back of the new pads where they contact the caliper and put them in.
11. put the caliper back on & brake line brackets back on.
might need a big breaker bar to loosen the 2 caliper bolts, they are tight!
