- Sun Jun 15, 2008 10:05 pm
#58642
ok so today i got new front calipers and installed them. after i bled the front brakes and it seemed fine until i was completely done and started to drive, the pedal goes down alot further then it used to, it also comes very close to the floor, and sometimes it did but still stopping the car. what do i do? i also have rear drums if that matters. thanks
- Sun Jun 15, 2008 10:09 pm
#58644
you are suppose to bleed the entire system. that means front AND rear.
- Mon Jun 16, 2008 10:48 pm
#58786
sounds to me your master cylinder might be going out. Your master cylinder isnt able to hold the pedal properly..
- Mon Jun 16, 2008 11:33 pm
#58791
but thats what i dont understand, it was working fine, then i replaced the calipers, i put new ones on and now its doing it! its so frustrating! i tried loosening the brake lines to the master cylinder until no air bubbles came out then bled all the brakes and it still does it.
