- Fri May 30, 2008 12:16 pm
#57064
If your question was "How do you remove the front knuckle from an Integra?" then id have said "Undo the 32mm hub nut, undo the brake hose from the solid pipe on the chassis, undo the 14mm nut on the track rod end and split it with balljoint splitters, undo the 14mm not at the bottom of the kunckle connecting it to the lower control arm and split it with balljoint splitters if you need too and then undo the 14mm nut attaching the top of the knuckle to the upper arm, again using balljoint splitters if you have to"
But i have no clue if thats what you asked or not
