- Wed Dec 31, 2008 1:02 am
#86229
You can't put an Integra master cylinder on a Civic brake booster. The mounting bolts are reversed. One is like this / and the other is like this \ .
- Wed Dec 31, 2008 2:21 am
#86251
Ah OK got you dude, so basically the whole thing's gotta be swapped out and the brake lines to the MC need to be modified slightly to connect to the MC as it's fixings are at a different angle to the civics MC which means the 1"MC CANNOT be bolted on to our civic boosters...is this all correct? I think if i've read correctly, i assume this is all correct with the info given here. thanks again, its a big help
suspendedHatch wrote:You can't put an Integra master cylinder on a Civic brake booster. The mounting bolts are reversed. One is like this / and the other is like this \ .
