By Adzgtr
#55393 pm sent
By Adzgtr
#55570 still awaiting a message :(
By Ecc0
#55611 Sorry for the delay PM sent
By Adzgtr
#55846 hey ok just saving up cash now :) thanks for the help guys if i go to prelude calipers will the VTI Master brake cilinder be enough?? and what happends if i used the lsi one
adz
By Adzgtr
#55997 i found out runnign my ap dot 5 fluid will help dont need the mastercylinder only the brake will be a lil more spoungy and i think will be easyer to let go if i lock up.
also i havnt bin told why i have to use vti hubs to fit the prelude calipers surly if i run the mounting points of the prelude calipers and mgzr discs it should fit ??
thanks for any help adz
By Ecc0
#56042
Adzgtr wrote:i found out runnign my ap dot 5 fluid will help dont need the mastercylinder only the brake will be a lil more spoungy and i think will be easyer to let go if i lock up.
The mounting points on the lsi wheel hubs are slightly small than that on the vit and prelude which means the vti or prelude calipors wont fit onto lsi wheel hubs.
By changing to VTI wheel hubs you will have a better starting point to pick any brake upgrade you want, hope this helps.
By Adzgtr
#56046 ok kool thanks thats what i though but i was told last night you didnt need the hub just making sure
