- Mon Oct 02, 2006 6:31 pm
#55
Parts list:
- Complete front spindles from 94-01 Integra (knuckle, caliper, rotors, lines, etc)
- 94-01 Integra brake booster
- Integra RS master cylinder
- 94-01 Integra proportioning valve
if you are doing the rear brakes too:
- Complete rear trailing arms from 94-01 Integra (knuckle, caliper, rotors, lines, etc) Your civic parking brake cable will work.
All parts are a direct swap, everything bolts right in.
Disconnect the brake lines. Unbolt the uper & lower ball joints & tie rod ends up front, swap the complete spindles. Now is a good time to replace the rubber brake lines with a set of stainless steel braided lines.
The rear trailing arms are also a direct replacement. Disconnect lines, unbolt & swap.
After you're done, be sure to get your car aligned, it is sure to need it!
