By undeadone069
#359373 OK got my coupe a couple weeks ago. Noticed for the past few days I'm hearing a buzzing sound from under the hood when I first crank it. When it makes the noise the motor bogs down. Upon looking for the problem I'm pretty sure it's coming from the abs stuff. And I see fluid down below it and looks like fluid side my passenger front rim as well. I been researching and found people with the same problem. They said they replaced o rings on the abs accumulator. And it fixed it. Anyone know about this. Or is it easier to remove abs. From what I'm getting this can be dangerous please help
By Driv-it-hard
#359398 I would try to Brake Part cleaner on everything and watch for travel of fluid. Remember, brake fluid is the strongest of fluids and it will eat through paint. Be careful where you let it sit.
By 95c1v1c
#359668 The bogging down is the ABS modulator pump charging the accumulator. The problem is probably in your solenoids since the pressure is bleeding off somewhere. is the ABS light on?
