By vince72310
#358131 Can someone please help me identify the front disc brake knuckle? I am getting the Wilwood DPHA Front Caliper and Drilled & Slotted Brake Kit, its fits just like OEM (10.2'') but this kit only fits the Ex/Si hatchbacks i have the DX model. I need to buy the knuckles from an ex/si but i have no idea how they look. I need to either go to the junkyard or find someone parting out. Please if you have any images or link please share.
Can't wait to slap these bad boys on!! :thumb:
https://www.jhpusa.com/store/pc/viewPrd ... tegory=119
By EconoBox
#358135 You just need to make sure they came of an EX or an SI otherwise you will have to measure the brakes and caliper mounting points to verify what they came off of. If you aren't buying from someone you trust or pulling them off at the junkyard yourself you may end up with the wrong ones. There is an option I linked below that may be up your alley though.
Instead of tracking down different knuckles you could just buy the full wilwood kit that fits your car for a bit more money. I use to have this on my sedan and it was great! You just have to buy their brake lines which aren't included. You just need to select the part number that fits the knuckle you currently have. :thumb:
https://www.jhpusa.com/store/pc/viewPrd.asp?idproduct=7924&idcategory=119
Crappy pic I pulled from my IG but this is what it looked like installed on my old sedan.
#358388 The EX/Si have larger rotors and calipers than the lower models. The Integra has the same sized rotors as the EX/Si, but even bigger calipers.
Rotors
DX/LX/CX/VX < EX/Si/Integra
Front Calipers/Pads
DX/LX/CX/VX < EX/Si < Integra
This is the general rule, there are inconsistencies between markets and even within the USDM market, 92,93 vs 94,95 and with or without ABS. It's up to you to confirm that you're getting the bigger brakes by measuring the front rotor to make sure it's 10.3 and not 9.4, or simply by getting Integra parts which have bigger front calipers anyway.
Knuckle Part # Comparison
http://www.hondapartsunlimited.com/auto ... uckle-scat
Front Brake Part # Comparison
http://www.hondapartsunlimited.com/auto ... ake-1-scat
http://www.hondapartsunlimited.com/auto ... ake-3-scat
