By beefystud
#357925 i have a 1995 canadian cx with with rear drum brakes, no-abs
is it possible to take 1996 integra trailing arms with rear disc that have abs and convert them
for my car, or do i need to find 1995 civic si non-abs disc trailing arms in order to make the swamp work ?
By suspendedHatch
#357927 Yes, ABS or not doesn't matter. Re-use your stock brake hoses. The brackets on the Integra rear parking brake cables don't all line up exactly because the cables are longer, but you can make it work and use the adjustment to get it tight. Si cables fit all other hatchbacks perfectly but they're hard to track down. Your other option is to buy them new from the dealership. Drum parking brake cables wont work.
