By brandoff88
#352323 after two days of searching and looking, I figured out my rotor and pad situation, I have also deduced that a 15/15th non abs master cyl from a 91 ex will bolt right up with no modifications to the hard lines, no I know I need a 40/40 prop valve but I would like something "bolt on" like the mc, I don't want to ghetto rig something that doesn't fit perfect, I need a 40/40 valve that will bolt on and requires no line bending, if someone knows of a model car that will bolt on directly (non abs of course) and fit my lines without modification that would be awesome...I just cant find a definitive answer
By brandoff88
#352324 jesus nvm, I found a post on here by accident, ill just use the 92 si 4040 sine it had rear discs and no abs lol
#352344 Finding an Si is like finding a unicorn. Any non ABS EG with rear disk brakes or any non ABS DC Integra is what you need. Or a Del Sol if you really are looking for unicorns.
#352429 Nobody said anything about bending lines.
All the prop valves I mentioned have the same physical dimensions.
