By 92dxeg
#334011 ok i have a 1992 dx hatch with the 8 inch rotors.. i have the front dick set up off a dc gsr teg 10 inch rotors now i plan on getting new wheel bearings ball joints tie rods. now i buy all of those parts as if i was buying them for a gsr teg right ? even the tie rods ect ect will the tie rods boilt right up too my eg..
also another question is i am going to get a rear disc convertion do i get one off a eg civic si, dc gsr, ls teg, or ek si? are they all the same ?
By blk92hb
#334046 You will need gsr wheel bearings, civic tie rods, and the rear disk dont matter where you get them they are the same, ek, dc, or eg.
By juls1488
#334050
blk92hb wrote:You will need gsr wheel bearings, civic tie rods, and the rear disk dont matter where you get them they are the same, ek, dc, or eg.
this.
just make sure to get the rear disc ebrake cables too.
also the lower balljoint is the same on 92-2000 civics and 94-01 tegs.
By 92dxeg
#334078 thanks guys so all the rear disc set ups are the same ? so when i go to a auto part store and get callipars and rotors they will all work and be the right sizes
