By Axix23
#333456 On an eg8, will rear disc brake stainless lines work on a rear drum setup?
Can I make them fit?
What exactly will be different in the 2 lines? Length of the line or the fitting ends?
:roll:
By Axix23
#333496 nevermind, they have diff fittings.
By Axix23
#333581 I was able to make it work with no modifications at all. Instead of hooking it up to the hardline from the shoe of the drum, you can run the stainless lines directly to the shoe. Fits perfectly.
