- Tue Sep 18, 2012 2:14 am
#315898
I'm swapping the front spindles, rotors, calipers and brake lines onto my 92VX. Everything lined up good except the brake lines from the EK are a couple inches too short. They will hook up but if I turned the wheels too far I'm sure it would bust the rubber lines. All of the threads I found about swaps say to use the soft lines from the brakes your swapping. The caliper end of the lines mount differently on EG and EK ,so I can't use the lines off the 92. What gives??
