By baconsauce
#306077 how do you adjustment the emergency brake on the car?
or if it gone bad does it need any part replacement?
thank you and I am not much experience with brakes myself.
By elrompetoto
#306081 Take off ur center counsel the one by the e brake handle u will c 2 10 mm nuts or 12 mm not shore put ur ebrake down tighten those up and pull ur ebrake up u will feel it get hard at a lower level
By baconsauce
#306160 matched up a theory in my brain
:thumb: :thumb: :thumb:
By baconsauce
#306202 I could not find those bolt when I took off the center console
do you mean that bolt at close to end of the handbrake?
By baconsauce
#306213 I just looked at it and right behind the hand brake and all i see is the thing hold wire with no bolts, just little dome and right behind it has bolt that are straight line along the handbrake
By baconsauce
#306223 Image
there the bolts next to my thumb
By elrompetoto
#306225 U c the spring that is holding the 2 lines all the way at the begging of the line there a but right there just tighten with the ebrake handle down
By baconsauce
#306226 its worked, firmly and much better
thanks brah :thumb:
By zer0
#307400 :thumb:
