By EGCiviCKid
#296903 hi, i have an lsi with standard brakes i have been researching the Front big brake upgrade and i believe i have everything i need
however have a couple questions i would like to ask.
are these all i need?
Integra Calipers with brackets and brake pads
A pair of MG ZR 160
or
Do i need the master brake cylinder also? or is this just for the rear conversion?
and brake lines?
thanks
By Apexracing
#297241 if you have disc brakes already you should be set, if you want to be sure just run to a parts store and get a cross reference of the integra and your civic's parts and see if they are the same.
