- Wed Jan 18, 2012 5:23 pm
#290829
hi guys, hello from costa rica, i have a quick question about an problem i have with the brake prop valve, i have a 35/40 prop vale that is leaking from the middle gasket, i already tried 3 prop valves and all 3 have the same issue, they worked great for about 3 days and suddenly starts to leak, any ideas Confused
- Thu Jan 19, 2012 12:20 pm
#290974
i only have the 1' MC with booster, thats all, i used to have it in another eg with no leaks, i tried the 30/30 ... 40/40 with no luck
- Thu Jan 19, 2012 2:37 pm
#290993
Well there has got to be more pressure some where in the system. Its a non ABS car correct? It could be that the MC is giving to much pressure out. or you have possible have a caliper that is not working properly.
- Thu Jan 19, 2012 2:54 pm
#290994
mmm well i haven't checked calipers yet, i''ll checked them and see if there's any issue with them
- Fri Jan 20, 2012 11:55 pm
#291277
by the way what's the brake bleeding sequence a cvici SI 92 HB.. i´ve seen posts that say, LF RR, FR LR or LR, RF, RR, LF, also longest to closest.. so dont know the exact sequence
- Sat Jan 21, 2012 1:30 am
#291288
It is passenger rear, then driver rear then passenger, front then, driver front Really it should not matter but that is the way they recommend that you do bleeding unless you have a mighty VAC then it should be rears then fronts that way it pulls evenly through.
