- Sat Oct 15, 2011 1:57 am
#277789
I did a rear disk conversion on my car coupe using my donor del sol. When I did the swap I replaced the booster and master cylinder with remanufactured units (Cardone brand) I left the stock Prop valve in opting not to swap the prop valve off of my del sol (I got lazy.)
Now whenever I drive, the pedal is EXTREMELY stiff, and my front brakes seem to be partially applied. On most days, I can drive about 30 miles or so, then the pedal gets stiffer and stiffer. It gets to the point were they completely locked up, and if I want to drive anywhere, I literally have to mash VTEC and keep the RPMs stupid high to drive where I need to go. Some days I won't have any issues, but for the last few weeks, It's been horrible. My fronts seem to be completely locked up. What gives?
