By intheworks
#257494 1991 accord no abs.....
changed front pads and then noticed the passenger side caliper wouldn't tighten back up when i hit the brake pedal. replaced the caliper and tried to bleed it but nothing comes out. Tried bleeding all 4 wheels and the opposite wheel in the rear is doing the same. the other 2 wheels (front driver side and rear passenger side) are good. what can i do??
By dawg316
#260980 possibility of no fluid going to the brake? maybe the lines clogged? when you took off your caliper was there fluid dripping from the line
