By MarkCayabyab
#248541 so like my brakes are screeching and i'm planning to change my brakes. The thing is i don't know what brakes are good. Are they all the same? Is there any brands that are good for me to look at? Like what do i need? Also, since im changing brakes im planning on doing a rear brake conversion too. any help guys? sorry total noob.
By OleFolk
#248545 Brakes are pretty easy to replace
Rust can be a headache
I recommend a bigger brake kit up front if ur serious
Otherwise id just replace pads and rotors plus rear disk
By MarkCayabyab
#248546 thanks loving the help :thumb: but what kind of bakes do you guys have? if you don't mind me asking. i honestly don't know where to get the pads and rotors.
By MG6
#248563 I have the stock OEM pads. Brembo rotor fronts. Rear are stock drum.
Difference? NONE but the rotor were cheaper with Brembo than stock
