- Wed Jul 21, 2010 8:55 am
#205599
k guys , my car is eg8 saloon with drum brakes at rear
two or three days ago i changed the front pads. i undo the brake lines, changed the pads, knocked few times the piston so i could put back everything again. first day feel bit spongy so i did bleed the brakes but then im loosing my brake ( probably didnt do it the correct way). found the article how to bleed brake. i followed every steps. i started from rear passenger side but this what i found weird, there is no fluid at all even i pumped the brake pedal. so i skipped that and moved to front. bled as in the article but still no brake at all.
i need to pick my wife n daughter in hospital, impossible without brakes... So anyone please help me, suggestion? did i broke the piston? why no fluids at rear? etc..
cheers.
cheers.
