- Fri Apr 23, 2010 2:29 pm
#189537
how to change brake fluid? i was reading manual, but i didn't find the answer. i know that dot4 is the fluid i need, but how to change it and how many fluid i need?
the easiest way for you to do it yourself would be to put it up in the air on stands, take all 4 wheels off and crack all four bleeders and let it graivty bleed out, make sure you catch the fluid in containers and then when the reisvor is empty, refill it with clean fluid and wait for the fluid to run clean out the bleeders, then tightn the bleeders and pump the pedal and double check and bleed all 4 bleeders... this may take some time and you will have to keep an eye on it, but its the best way to do it with out putting a bunch of air into the system, and i dont care for vacum bleeders either... hope this helps...
PANDA CREW No.20
PANDA CREW No.20
