By 95CivEg
#173954 Ive been seeing some small drips under my car lately and def. not oil-
looked under the hood and there is a small area where brake fluid has been leaking from the UNDER side of the booster not the master cylinder/
Anyone have an idea of what is causing this before i take shit aprt?? lol
Thanx in advance*
By Classiccarsrule85
#173956 hows your clutch? it could be leaking form there and traveling to where you are seeing it....however more likely it is leaking near the master cyl....is there any rust on your brake booster? if so more than liekly the rubber seals are deteriorated and thats whats causing the leak....
By 95CivEg
#173959 i dont think the clutch but ill take a quick phone pic. n post it
By 95CivEg
#173960 Didnt see this b4 but its comin from right where the bolt is...??
(sorry for sideways pic)
By That One Dude
#173968 That's the aft most seal on the master cylinder. You need to replace the master cylinder.
Has your brake pedal been soft or overly hard?
By Sentry
#174022 BMC is only like 50 bucks, replace it, should be good to go.
By 95CivEg
#174023 yea lil softer than normal thanks :thumb:
