rotor size confusion
Mon Jan 11, 2010 7:11 am
by EG6666
Currently I'm at a state where I'm planning to get rid of the drums and on a budget, I'm a bit confused on the rotor size between the jdm spec eg6 rear rotor size and regular ls/rs/gsr rear rotors. Gsr/ls/rs rear rotors are 9.4" and according to some member from ht says the jdm spec eg rear rotors are 9.6", does anybody have info on this? I'm asking this because both jdm eg6 rear rotor and gsr rear rotor are available to me and if in fact the rear eg6 rotors set up are bigger i will go for that.
thanks
Mon Jan 11, 2010 7:33 am
by GSRSI
well with being in the rear it wouldnt mater with .2 size differnce if it was the fronts id say go for it.. and you can probly get more avaible parts for the gsr, i would say got with the gsr.. remember you rear brakes only do 20-30 % of your braking
Mon Jan 11, 2010 3:10 pm
by Graham
Eg6 ones are 240mm or 9.4" so theres no difference. They're also shite, 260mm ones are better
Mon Jan 11, 2010 8:16 pm
by EG6666
Cool, thanks for the info guys! Think im goingto go with the gsr swap.
