Loud popping noise in the front. Replaced nearly everything.
Hey everyone! I was reluctant to post this but after replacing almost every suspension component, the problem persists.
The problem: with the wheels turned to full lock (to the left only) I begin to move the car and a LOUD popping sound can be heard from the driver's side wheel well.
Replaced so far:
- LCA bushings + compliance bushings in May 2017 + installed front sway bar (it didn't have from factory) - popping noise was almost undetectable
The popping noise got gradually worse over the last year:
- Si knuckles + brakes obviously + upper control arms - May 2018
- LAST WEEK: Replaced front struts, keeping my old lowering springs, new top mounts, new lower balljoints - popping noise still there, as bad as ever
Could it be the steering rack? I've inspected every part on the car, subframe seems ok, tie rods feel solid... I'm honestly out of ideas. I will replace the sway bar and lower LCA bushings since they are 1,5 years old but honestly I don't think that's the problem.
I hope someone can give me an idea. Thanks!
Replaced so far:
