- Sat Apr 05, 2014 4:46 pm
#344136
So, what happened with this car. Did Honda have a brain fart and just forget about putting in a rear bar. I have Eibach Sportline springs and Tokico Illumina struts. And this car understeers badly. I'd like to go pretty stiff on the bars. Because for daily driving I can dial down the struts to soft. Does someone make a complete balanced from and rear competition type sway bar kit for this car?
- Sun Apr 06, 2014 3:58 am
#344150
Anyone?
- Sun Apr 06, 2014 5:46 am
#344157
OEM Integra Type R rear sway bar is the way to go! Best bang for your Buck!!
*MY FOR SALE THREAD*
http://civic-eg.com/viewtopic.php?t=25441
*BUILD* My eg Hatch so far: http://civic-eg.com/viewtopic.php?t=22357
- Sun Apr 06, 2014 9:41 pm
#344171
Whiteline
- Wed Jun 04, 2014 1:09 pm
#346131
I have same hatchback, dx , red , fivespeed. I went to my local junk yark and found my a complete front and rear suspension of a 96 integ . Rear sway , front sway bar, front lower control arm, rear L control arm. The best thing to do before installing. Get your self the energy suspension Poly bushing kit , Dont forget the trailing arm bushing that does not come with the kit. it is separate. The you can upgrade from there.
Hope this helps.
Hope this helps.
- Thu Jun 05, 2014 4:47 pm
#346178
That car came with a rear swaybar and someone took it off. Do your rear LCAs have swaybar mounts?
Progress makes the best rear swaybar. Better than the ITR bar + overpriced blingy reinforcements making up for the poor OEM design.
- Thu Jun 05, 2014 4:58 pm
#346179
The DX model has no hole for any sway bars on the LCA.
You have to use the stock LCA from the Integ or EX or Si model. If you are using an aftermarket bar that is wider than the 19mm stock bar for the rear, I recommend a brace for the rear. Just in case of tear out.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
