- Fri Aug 30, 2013 2:39 pm
#336143
Any one has any ideas on what I can use to increase the height of my suspension to about an inch. I have skunk 2 drop low springs.
- Fri Aug 30, 2013 3:18 pm
#336146
Only lowering springs right? You might need a set that has a less drop
- Fri Aug 30, 2013 7:29 pm
#336156
I would get a set of coil over sleeves/springs; the kind that go over your current shock/strut. (Assuming you already have some aftermarket ones)
That way you can fine tune the ride height.
- Fri Aug 30, 2013 11:10 pm
#336169
This is exactly what I did before I got my skunk 2s.
teal_dx wrote:I would get a set of coil over sleeves/springs; the kind that go over your current shock/strut. (Assuming you already have some aftermarket ones)
