- Thu Oct 18, 2012 5:32 am
#318136
these are megan racing but most coilover system are same
http://www.meganracing.com/tech/install ... been%20set
EJ1_MK wrote:So what is your question here, how to adjust the ride height? By the diagram number 2 is the collar you loosen, it and then spin the bottom part number 1 and it will raise and lower the car. Now you don't want to touch collars 6 for any reason cause it will adjust your spring rate and possible throw off the handling of the car.
