- Sun Mar 25, 2012 3:42 am
#299702
Alrite. Like title says im lowering my car. I havnt rlly done to much research into this, but from what ive read im gonna need new struts, and springs... Also wats the difference between coilovers and just lowering springs? And also will i need a front camber kit, i already have the rear.
- Sun Mar 25, 2012 4:05 am
#299705
coilovers are pretty much adjustable springs but connected to the strut that is made to lower the car without destroying the ride quality..be prepared to spend upwards of 400-500 for a decent set unless you go ebay in which it will ride like a hay wagon.
- Sun Mar 25, 2012 4:31 am
#299711
Springs are cheaper but you won't get to adjust the height of your car. You can get a decent set of coilover sleeves for around $200-$300. Just be careful using either of these with stock struts. They aren't meant to handle the car sitting lower so there is a chance they'll blow out.
Now if you can afford it, you could get full-bodied coilovers which will run you around $800-$1000 for a decent set.
I've been looking to lower my car as well so I've been reading up on this subject. Here is a good thread to read to learn more about suspension setups: http://civic-eg.com/viewtopic.php?t=1683
92 Civic CX Hatch Project: http://www.civic-eg.com/viewtopic.php?t=16256
- Sun Mar 25, 2012 6:04 am
#299714
What are you going to be using it for? The track, just daily driving, daily driver with occasionally weekend track?
EBay coilover sleeves are junk
stay away if possible
Full body coilover are more pricey but handle better and can adjust height[/u]
http://civic-eg.com/viewtopic.php?t=17296
My for sale thread check it out!
http://www.civic-eg.com/viewtopic.php?t=25828
#3 CivicEG.com Ferio Squad
- Sun Mar 25, 2012 7:07 am
#299720
coilovers are the way to go! (NOT Ebay ones as mentioned several times above)
It really all depends on how stiff and low you want your ride to be, my old eg9 (no one knows about hahaha!! wasn't on the site at the time) had just aftermarket struts and springs. It was riding on tein springs + Tokico Illumina struts. Gave the car about a 1.5" drop and was surprisingly quite comfortable.
If you want something that is cheap and comfortable, (dont want to spend so much on coilovers) for Daily Driving and should last, I can suggest some Tokico Blue HP struts (around $300 shipped I think) and some Tein S-Tech springs. That will give you a 1.5" drop, comfort and its quite affordable for the quality parts you are buying. This set up will cost around $500?
Or buy some good coilovers for $800-1000 and adjust the height whatever way you want!
This was my old set-up:
*MY FOR SALE THREAD*
http://civic-eg.com/viewtopic.php?t=25441
*BUILD* My eg Hatch so far: http://civic-eg.com/viewtopic.php?t=22357
- Sun Mar 25, 2012 12:34 pm
#299734
I am running ebay coilovers on mine until i get the money for good ones doesnt rde to bad alot better than my f250
My family man sedan
http://civic-eg.com/viewtopic.php?p=314391#314391
hgm b16a coupe build thread http://civic-eg.com/viewtopic.php?t=22844
teal dx dd build thread http://civic-eg.com/viewtopic.php?t=23254
- Sun Mar 25, 2012 5:14 pm
#299768
I am on eBay coilivers and there not bad as long as you don't slams them out
rak511 wrote:Ya... its just a daily driver... im looking for as cheap as possible without going to ebay... but im looking to drop mine about 2 to 2.25 inches... wat do u guys suggest for that much of a drop?
My family man sedan
- Mon Mar 26, 2012 3:44 pm
#299850
From what I understand, eBay coilovers work pretty well for a while but then they start to wear out and ride like crap. Have a look at these: http://www.meganracing.com/product_deta ... 9&catid=47
Not bad for $170 and I've read nothing but positive reviews on them. Probably what I'm gonna put on my car.
- Tue Mar 27, 2012 12:15 am
#299915
Just make sure if you go with spring or sleeve over coil overs to get shocks you can ride on stock struts if you get springs like an eibach pro kit but if you go with sport lines or any other spring you will want to get struts other wise you will get about 6 months out of the stock ones if they are in good shape before they blow out. There are many good set ups for Daily use.
- Tue Mar 27, 2012 12:30 am
#299916
I got a full set of megan racing 1.75 inch drop lowering springs for 195 shipped. Would recommend to anyone. Fairly cheap and ride good no bounce.
