- Fri Mar 16, 2012 1:54 am
#298419
i could be off base here but isnt the down pipe lower than the oil pan on most hondas so it would be gone if the pan was being dented....if pan is in fact dented from slammin pavement get a used one and weld on some plate i did this with my VW cause the pans on those are LOW and the exhaust exits the back of the block so it doesnt protect the pan.
what size tires are you running?
i would guess the boot in need of repair would be a CV boot which is a cheap repair if you DIY or possibly a steering rod boot.
back to the original post when you say "sway" do ya mean drift across the roadway? if so the toe problem would have been causing that and probly wore the crap out of your tires at the same time.
and lastly forget raising it.
