- Fri Mar 09, 2012 5:56 am
#297552
I am going to install my coilovers tomorrow so i was wondering if anybody had some tips to do it , and would i be able to get REAR LCA strut bolts at any hardware store??? Or can i only use oem
- Fri Mar 09, 2012 6:32 am
#297557
A cut off wheel and an air hammer will make it a simple change over if your bolts are siezed. can use hardware store bolt's. Just make sure you use grade 8 bolts.
- Sat Mar 10, 2012 2:45 am
#297653
make sure you get an alignment afterwards
- Sat Mar 10, 2012 5:25 am
#297685
If you're using rubber bushings make sure you loosen all pivot points until the car is at your desired ride height, then tighten.
If you don't the bushings will fail prematurely.
Poly bushings will help here since they rotate freely.
- Sat Mar 10, 2012 4:02 pm
#297715
speaking of that, an energy suspension bushing kit is never a bad idea
SL93ex wrote:If you're using rubber bushings make sure you loosen all pivot points until the car is at your desired ride height, then tighten.
