By FG2_Andrew
#285493 Rules of the thread:
1. include any and all SUSPENSION components
2. do NOT include motor specs, exhaust, interior/exterior mods
3. do USE this thread for discussion!
4. Please, try to remember to post each "version" of your stance in separate posts. If you have had multiple setups, make a new reply for EACH setup.
How to post in this thread:
1. post one picture of your car from a side angle (no JDM angles please!)
2. fill in the following information
    - coilover/spring brand:
    - cost of suspension:
    - where did you buy:
    - how much drop:
    - camber kit brand:
    - degree of camber:
    - wheel/tire size (ex. 12x3 with 123/12/12):
    - offset/backspacing:
This list is to help others find what looks best to them and help other members make informed decision about what suspension is right for them! DO NOT FLAME IN THIS THREAD! this is not a thread about hellastacedflushdopeslammedhellacrazyoffsetbrohella.. so if someone isn't slammed, it doesn't matter.
IF YOU WISH TO POST NON-92-95-CIVICS, please use this spec list:
    - YEAR:
    - MAKE:
    - MODEL:
    - how much drop:
    - camber kit brand:
    - degree of camber:
    - wheel/tire specs:
AGX
+ pkaewthong34 [v1.0]
AMR
+ bks84 [v1.0]
BLOX
+ 92EG-8 [v1.0]
BUDDY CLUB
+ jefferydclark [v1.0]
EIBACH
+ 1992HondaCivicHatchDX [v1.0]
+ ceelx [v1.0]
COSMO RACING
+ teal_dx [v1.0
CUSCO
+ Graham [v1.0-2.0]
Dropzone
+ dodger [v1.0]
+ TrailerTrash [v1.0]
D2
+ Graham [v1.0]
eBay (generic) sleeves
+ egsedanguy [v1.0]
FUNCTION & FORM
+ Brandonthesmith [v1.0]
+ egbeegee [v1.0]
+ eg-guy [v1.0]
+ EH2_andy [v1.0]
+ *EVE* [v1.0]
+ slow92vx [v1.0]
+ tegpower18 [v1.0]
+ 94_jdm_ferio [v1.0-2.0]
GROUND CONTROL
+ drivehrideh [v1.0]
+ eg-guy [v1.0]
+ hatchie [v1.0]
+ juls1488 [v1.0]
+ 92EG-8 [v1.0]
GODSPEED
+ crazy-88 [v1.0]
H & R
+ brandonoff88 [v1.0]
+ Renegade [v1.0]
KONI
+ robster [v1.0]
KSPORT
+ Greasedmonkey [v1.0] [v2.0]
KW
+ elrompetoto [v1.0]
MEGAN
+ JohnRM [v1.0]
RACELAND/ROKKOR
+ lmlp640r [v1.0]
RACING GEAR
+ Graham [v1.0]
SKUNK2
+ Animal78 [v1.0]
+ Cl9junky [v1.0]
+ EJ1_MK [v1.0]
TANABE
+ Axix23 [v1.0]
+ iLLson [v1.0]
TEIN
+ blk92hb [v1.0]
+ Graham [v1.0]
+ mADmAN [v1.0]
+ 1-low-92-EG-Sedan [v1.0] [v2.0] [v3.0]
Voghtland
+ boggy [v1.0]
Yonaka Motorsports
+ EG Love [v1.0]
OTHER MAKES & MODELS ///
Ground Control
+ *Eve* [v1.0] -- 2000 Honda Prelude
Neuspeed Race
+ FG2_Andrew [v1.0] -- 2007 Honda Civic Si
IF YOU HAVE UPDATED OR ADDED TO YOUR SETUP, PLEASE BUMP THE THREAD AND LET EVERYONE KNOW WHAT HAS CHANGED!!! DO NOT DO IT IN YOUR ORIGINAL POST ITSELF SO I CAN LINK IT
#285566 Image
-KSport Kontrol Pro
-$560 way back
-Online shop...cant remember.
-No camber kit
-Would have to get another alignment to tell you the camber right now.
-Work RSB 15x6.5 +42 with Falken Azenis 205/50R15
#285567 Image
- KSport Kontrol Pro
- $700ish?
- Same online place as the others...
- No camber kit
- Still dont know...
- RS Watanabe 15x6.5 +45 with Falken Zeix 502s 205/50R15
By 1-low-92-EG-Sedan
#285604 - Tein Basics adjustable coilovers = came with car and bought car for $1,100..so they payed for them self :thumb:
- K-Sport LCA's = came with car as well
- ASR subframe brace = $100
- DNA motoring front and rear upper strut bars = $40 each
- about 3" drop from stock ride height
- front camber -2.5 rear camber unknown
- no camber kits
- 15" GSR Hammers with Firestone Precision Sport 195/60/15 (the tires came with the rims...and i will soon be getting new tires with the correct size side wall ..i rub A LOT...)
sorry but this is the best front/side pic i have of my car the way it currently sits
zzz by Busone10, on Flickr
Last edited by 1-low-92-EG-Sedan on Thu Sep 27, 2012 3:30 am, edited 2 times in total.
#285605 Image
my flush stance
my slammed stance
- Function Form Type 1's
- 850$
- Colivers from a local "jdm" seller.. camber kits.. Inlinefour
- flush with the tires
- Buddy Club P1 front and rear camber kits
- stright as poss
- Rota Circuit 8's 15x6.5 with Falken Ziex ZE 502's
- DA(91 teggy) rear disc conversion with stock DA rear sway bar
yes i know you said one pic.. but my car has been thru 2 diff set up and this will help
By FG2_Andrew
#285618 updated list... more stances and specs! :thumb:
By robster
#285630 Energy Suspension bushing kit , ITR topmounts
- coilover/spring brand: Koni coilover Chrom Edition 1150-5006-1
- springrate: front 52 N/mm P // rear 30 N/mm P
- cost of suspension: 900,-€
- where did you buy: e-bay
- how much drop: front 70mm / rear 60mm
- tread left on coil: front 15mm / rear 25mm
- distance from wheelcenter to fender: front 290mm / rear 300mm
- camber kit brand: front stock / rear ingals
- degree of camber: front -2°20' / rear -1°30'
- wheel/tire specs: Dotz Dakar 7x16et13 / Vredestein 175/50-16
By tegpower18
#285634 - coilover/spring brand: Form & Function type1's
- cost of suspension: 650$
- where did you buy: Weaksauce
- how much drop: 3.5"
- camber kit brand: Skunk2
- degree of camber: 0
- wheel/tire specs 15x8 et35
By JohnRM
#285646 Image
-Megan EZ Street coilovers
-$640
-PannAuto in Clairemont Mesa, San Diego
-3inches?
-P1 Buddy Club front and rear
-NEGATIVE 3 degree all around
-Konig Wideopen +20 offset/195/55/15
By boggy
#285654 Voghtland Integra lowering springs (no drop on lighter civic, but firm ride), craigslist new unused, $90
Front shocks: Koni yellow, tirerack.com, $150 each
Rear shocks, factory original
Tires: General Altimax HP, 185/60/14, tirerack.com, $70 each
Rims: KMC aluminum from 1995, 13.5 lbs each, painted semi gloss black
Not a "stance" really, just adding to the data pool
May lower later after I run this setup a while. It rides and handles perfect, so I hate to mess with it.
By eg-guy
#285697 dirty cell pic, dirty pos.
-function & form type 1's
-$1058
-jhpusa.com, bwr.com, ebay
-? coilovers turned all the way down
-blox front camber kit
-unknown degrees
-bwr rear lca's
-es master bushing kit
-es trailing arm bushings
-00 integra rear disc-
-00 integra 14mm rear sway bar
ls mesh wheels, 195 55 15 kumhos
-diy rolled fenders
By hatchie
#285721 Image
old setup:
ground control coilovers with eibach springs kyb adjustable struts
amount of drop..... >4inch
Skunk2 pro s camber kit on front and buddy club on rear
front camber was set at -7.0
rear camber was set at -8.0
cost of suspension .... around 1200
wheels:
miro stp1 16x9 et 15
federal 595 evo tires 195/40 16
By EJ1_MK
#285723 - coilover/spring brand: Skunk2 Pro-C
- cost of suspension: 3k +
- where did you buy: PasswordJDM
- how much drop: A lot
- camber kit brand: Skunk2 Pro front and rear
- degree of camber: -1.5 front -1.0 rear
- wheel/tire specs Konig Helium 15x 6.5 205 50R/15
By FG2_Andrew
#287762 moar stanz plz!
By Animal78
#288121 I'll play.
93 hatch
Skunk 2 sport shocks
Skunk 2 coilovers
Lowered about 2.5 inches
Camber is -2.5 front -2.0 rear
Wheels are drag dr20 15x7 et10
Front tires are federal ss 195/45-15 rear is kumho ast 195/50-15
