By eg-guy
#334021
juls1488 wrote: coilover/spring brand: Koni/GC with GC Extended top mounts 340f/250r
How do you like the ride with OTS GC spring rates? I'm debating a few different spring rates. 1. 400# 350# 2. 400# 450# 3. OTS rates
By juls1488
#334029
I love them. They handle awesome. I stuck with the ots rates cause a lot of the roads by me a terrible so a higher spring rate makes me wanna die haha.
For daily driving the ots rates are great. If you plan on tracking it at all definitely consider a higher rate. Your second choice is what I would go with if I was going to daily and track my car.
The only thing I wish had done was match the front and rear rates. I personally feel that 250 is a little too soft for my liking, a 350 or 400 would've been better.
One thing I definitely recommend is shelling out the extra for the extended top mounts. They allow you to go pretty low with out having any gap or sacrificing shock travel. And they look sweet.
G/C + Koni yellows, ITR sway bars and poly bushings all around makes for a really tight handling ride.
By eg-guy
#334044
Thanks for the reply it helps a lot.
By dodger
#334052 - coilover/spring brand: dropzone
- cost of suspension: free
- where did you buy: local
- how much drop: 3-4 inches
- camber kit brand: none
- degree of camber: none
- wheel/tire size 15x7.5 /195/50/15
- offset/backspacing: 30 offset
By mADmAN
#334097 adding to the data pool
- coilover/spring brand: TEIN Type Flex
- cost of suspension: Came with the car
- where did you buy: Came with the car
- how much drop:theres a 1.5-2 finger gap between tire and fender.
- camber kit brand: Buddyclub front and Hardrace rear
- degree of camber: Front -0.1 and rear -1.5
- wheel/tire size (ex. 12x3 with 123/12/12): 15x7 with Federal 595 RS-R 205/50/15
- offset/backspacing: +33
By 92EG-8
#334496 - coilover/spring brand: Tokico blue shocks ground control sleeves
- where did you buy: Came with the car :)
- how much drop: 2inch I think? Still have more to go
- camber kit brand: BWR
- degree of camber:
- wheel/tire size: 15x7 195/55/15
I'm the hatch in the rear
By pkaewthong34
#338599 - coilover/spring brand: AGX coilover and shock
- cost of suspension: i got it off craiglist for 150 on those set lol
- where did you buy: craiglist baby !
- how much drop: i think its 3" or 4"
- camber kit brand: ebay (on its way actually )
- degree of camber: front = -3 and rear i have no clue
- wheel/tire size: 15x7 hankook ventus 195/50/15
- offset/backspacing: not yet
By Apexracing
#338637
pkaewthong34 wrote:- coilover/spring brand: AGX coilover and shock
- degree of camber: front = -2 and rear i have no clue
That looks great!
By TrailerTrash
#338641 - coilover/spring brand: DropZone sleeves on Skunk2 sports
- cost of suspension: $200
- where did you buy: craigslist
- how much drop: alot.
- camber kit brand: Wicked Tuning on the rear and Buddy Club P1 on front
- degree of camber: no clue
- wheel/tire size: 13x5.5 Centerline steelies with 175/70/13s
- offset/backspacing: +30ish
By eg-guy
#338762 - coilover/spring brand: Koni/GC/ebay extended tophats f/r
- cost of suspension: $430/$325/$98
- where did you buy: tunersports/ebay/ebay
- how much drop: 2-2.5in
- camber kit brand: N/A
- degree of camber:
- wheel/tire size: OEM 99-00 si wheels 15x6, Falken ze 912 tires 195/50r15
By Axix23
#339760
TrailerTrash wrote:- coilover/spring brand: DropZone sleeves on Skunk2 sports
Looks good man. Love them wheels!!!
By Renegade
#340733 So I'm new to this forum and here's my first post before I can post pictures lol. Sorry for all the noobyliciousness.
By Renegade
#340734 - coilover/spring brand: Koni's w/ H&R Springs
- how much drop: About 2 Inches
- camber kit brand: None
- degree of camber: About 1.5-2 Degrees all around
- wheel/tire size: 16x7 DR31's 195's up front, 205's in back. (Because of all my rwhp........)
- offset/backspacing: +40
Hopefully I will be getting some CCW Classic reps soon.
16x8 ET 20... Please don't rub!
By jefferydclark
#340740 here is my setup.
- coilover/spring brand: BUDDYCLUB N+ FULL COILOVERS W/ DAMPERS
- how much drop: About 3 inches
- camber kit brand: BUDDYCLUB P1
- degree of camber: not sure...the back isn't cambered at all. my fenders are all rolled and pulled.
- wheel/tire size: MRR FF5 15X8 OFFSET FALKEN 195/50
- offset/backspacing: +25
By 1-low-92-EG-Sedan
#341184
jefferydclark wrote:here is my setup.
car looks awsome man..good job!! :thumb: :thumb: :thumb:
