- Fri Nov 04, 2011 10:23 pm
#280143
bks84 wrote:asianrob wrote:i never used the prop valve. and mine worked fine. if you do decide the prop valve the one from a 92 SI will work since it has disc brakes but no abs the integra one wont fit from what it looks like.
and the 91 civic ex master cylinder will work to i think its 15/16?
but when i did the rear disc brake swap i never had to use the prop valve and my braking was fine. that is just from my experience with my brake swaps i did. but yes the those bushings will fit. as long its from 94+ integra or 92-00 civic.
Why wouldn't it work? I used a prop valve from a 91 ls integra (90-97 use same prop valve and same booster/MC as long as they're non-sbs), didn't require any modification of the OEM lines.
Personally I'd use the 40/40.
if i remember right those (well the abs ones are atleast and like 99% Of those are never RS's you'd see in the salvage) they look like the octopus ones. where they are like all over the place and not like 2 up top and 2 on bottom ? if i had a pic you'd see what i mean.
but i think the 96-00 DX/ 99-Si would be suitable my friend did that swap and it ended up being the same prop valve. on his 96 dx
and yes the sway bar will bolt up with those integra brackets and Rear lower control arms.
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
