By 92dxeg
#275852 ok guys i have a bad wheel bearing on my passanger side the hub is also shot witch fucks up the wheel bearings. my buddy gave me the whole driver side spindle off his old hatch would this work on my passanger side ? or will the brake calliper not match up ? help if u can
By EJ1_MK
#275855 depends on the models of the two hatches if its a SI it will have the bigger rotor and brake set up the others are all the same with the smaller brake setup and will be a direct swap with out any issues.
By EJ1_MK
#275862 man I must be really tired not to read that right RWMIII is right it won't work you could remove the hub from that spindle and put into yours and fix it but no way you can put a drivers side on the passenger side
By eg-guy
#276293
RWMIII wrote:wont work. the tie rod end mounting wont be on the correct side of the spindle. or the brake caliper and lines.
true :thumb:
