By ForneyHatch - Fri Sep 09, 2011 2:14 am
#270978
I have an EG and I would like to get an adjustable upper balljoint camber kit. I am considering either INGALLS FRONT BALLJOINT CAMBER KIT or SPC Front Camber Ball Joint. I replaced the old rubber bushings with polyurethane in the upper control arm and I need a camber kit. I figure, since my upper ball joints are 17 years old, its time to replace em. Might as well buy adjustable camber balls while I'm at it. This is my second car that I plan on occasionally taking to open track days. I will not be doing an aggressive drop in height. Does anyone on this forum have experience with these two products? If so, which one whould be better or should I just rethink my suspension setup?
FYI, I have complete polyurethane bushing kit finally installed and I'm ordering Tokico Illuminas and Ground Control Coilovers. I know that there is some disagreements about even needing camber kits. I'll appreciate any constructive criticizm.
1994 Civic CX B16A...Who needs A/C or Powersteering anyways?
