- Sat Sep 03, 2011 5:16 pm
#270241
For road racing, you might as well go big or go home with the rear sway. 14mm is going to be a huge upgrade from nothing, and you will definitely feel the presence of the rear sway. Since you already have the 14mm bar in your garage, throw that on with your Integra rear suspension/brakes, and get used to driving the car with a front and rear sway. Then upgrade. You will be amazed at the difference in handling.
My second Teg had 24mm front and 14mm rear (GSR components), third Teg was an ITR with 24mm front and 22mm rear (stock, USDM components) but that was a different story all together on handling.
I've found that 24mm front and rear bars on an Integra is a perfect setup as I experienced on my buddy Ben's GSR with stock shocks/spings and an ASR rear brace and 24mm bar. Granted, the Civics are lighter than the Integras, so you might be able to get away with a 24mm front and 19mm rear.
I drove an Integra with the 99-00 Si front bar and ASR 24mm rear bar and found that it had way more understeer than I care for. I personally like a little oversteer so I can plant my foot on the throttle right after the apex of the corner and straighten out that way. Not to mention, oversteer is easier to correct than understeer, especially at speed.
