By eg-guy
#268497 Ive never replaced a front wheel bearing before, has anyone on here done this themselves?
Is it hard to take the part off that holds the bearing and then take it to a mechanic to have the bearing pressed in?
any help would be great
By ExCoupe94
#268518 cv joint, caliper, upper and lower ball joints and the tie rod shit pops right out if the upper joint is being a pita take the whole a arm haha. no need to undo brake line i believe just suspend the caliper. good way to save $$$ :thumb:
By eg-guy
#268569 ^^ thanks for the input guys, that write up helps alot!!!!
