- Sat Jul 09, 2011 1:04 am
#262896
All depends on what you want to do with the car if it is your DD then I would go with springs and shocks from any company. Cutting springs is bad and even if some says they have done it before it is not safe to do. If you want more aggressive then go with a aftermarket strut and a sleeve over coil over kit, and you can get different spring rates most of the time. More than that just buy a set of Full bodies.
Full Bodies are going to be the most adjustable but you will want to buy camber kits and get it alignment when you do anything. DO not be fooled you can run your car with camber but your tires will wear out faster PERIOD. There are several good brands of full body coil overs out there D2, K Sport, Function Form, Skunk2, Buddy Club, Maegan Racing, etc. All depends on where you want to go with your car as well.
95 EJ1 BG33P -
RC
95 EJ2 BG33P -
DRC
Coupe Crew #20
