By cjw_89
#231215 it is pretty straight forwrd.Be sure to pb blast the bolts and let them sit for a day or so.Remove the bolt for your strut l/r.Remove the bolt for your trailing arm l/r/.Unbolt your sway bar if you have one.Then last but not least remove the inner bolt,closest to your gas tank straps.Then reverse order of removal and your done.
By Eg6H2D
#231218 Use this. just follow the parts for the control arm.. more towards the bottom...
http://civic-eg.com/viewtopic.php?t=4129
By cjw_89
#231643 loving the 3rd brake light 8) I bought a roller for $200 omni power lca(rear) camber kits f/r(omni power) sirII cluster and cf duckbill.So i didnt complain.That Over $200 in parts there sure :) Go for it i say!
