By chewse
#219263 hey guys i've noticed that the eg's carry different rear stock struts..theres the one with the fork'd end where the strut bolts on to the rear lower arm and the other as like a round hole with a bushing which go into the lower arm......i just wanna know are these struts interchangeable as i'm havin problems installin the fork'd ones where i removed the ones with the round hole
By Gunni
#219287 i thought EG's had all the same fork ones ????
maybe u have a rear integra suspension ??
lca's from integra (upper) and eg (lower)
By chewse
#219294 on the usdm eg's is the bottom of the strut rounded or forked?......on the jdm models some are forked while others are rounded with the hole for the bolt.....i just wanna know are they interchangeable
By Gunni
#219303 unless u swap out the lca, it will be like putting a square cube trough a round hole .
By chewse
#219556 that makes sense...thnx mate
