Page 1 of 2
Honda Sway Bar Sizes
PostPosted: Tue Sep 07, 2010 5:02 am
by Greasedmonkey
Some people wanted to know what the stock sizes were for the sway bars for our EGs. I looked around and found out these sizes. If you dont agree, post up proof of what you disput. I will then change it.
Front:
1992-1995 Civic Si: 21mm
1992-1995 Civic EX: 21mm
1994-1997 del Sol DOHC: 24mm
1996-2000 Civic EX: 22mm
1996-2000 Civic HX: 22mm
1999-2000 Civic Si: 26mm
1997-2000 Civic Type R: 26mm
1994-2001 Integra LS: 22mm
1994-2001 Integra GSR: 24mm
1996-2001 Integra Type R: 24mm
Rear:
1992-1995 Civic EX: 13mm (when equipped)
1994-1997 del Sol DOHC: 15mm
1999-2000 Civic Si: 13mm
1997-2000 Civic Type R: 22mm
1994-1999 Integra LS: 13mm
2000-2001 Integra LS: 14mm
1994-2001 Integra GSR: 14mm
1996-2001 Integra Type R: 23mm (JDM) 22mm (USDM)
PostPosted: Fri Oct 29, 2010 2:10 am
by Eg6H2D
Just what I was lookig for :hehe:
PostPosted: Mon Nov 22, 2010 9:09 pm
by Eg6H2D
Bump!!! :thumb:
PostPosted: Tue Nov 23, 2010 7:59 am
by Ajax1989
so im gonna take it the lx sedan is the same size as the ex/si??
and wat about the 91 DA rear swaybar do you know what size it is?
PostPosted: Sat Nov 27, 2010 1:25 am
by EJ1STYLEN
So can i put a 24mm sway bar from a 94 integra gsr onto my 94 civic ferio?
PostPosted: Sat Nov 27, 2010 4:53 am
by asianrob
EJ1STYLEN wrote:So can i put a 24mm sway bar from a 94 integra gsr onto my 94 civic ferio?
everything swaps in but the end links are different from the NON GSR/Type R
IIRC
PostPosted: Sat Nov 27, 2010 9:52 pm
by That One Dude
You can put it in. The only difference between the GSR/GS end links and the LS/ITR end links it that the GSR/GS end links are more or less ball joint style. They will bolt straight to the front LCAs on the Civic.
PostPosted: Mon Nov 29, 2010 3:31 am
by EJ1STYLEN
Ok I'm kinda confuse, I could use the 94 gsr sway bar but not use the gsr end link? Or I could use. The gsr end links too?
PostPosted: Mon Nov 29, 2010 3:34 am
by That One Dude
The GSR sway bar will bolt straight up. No issues.
PostPosted: Wed May 25, 2011 3:21 pm
by OleFolk
Will a crx front sway bar fit on an eg?
PostPosted: Fri Jun 10, 2011 11:54 pm
by Eg6H2D
OleFolk wrote:Will a crx front sway bar fit on an eg?
Nope itll fit a DA and vice versa.. EG and DC are at most compatible in every possible way!! interchangeable parts..
PostPosted: Sat Jun 11, 2011 12:17 am
by Ajax1989
your correct sir!
and if anyone asks the rear ef/da bars fit the eg, wit the eg mounts tho
a ef/da sway bar on my car
pic
PostPosted: Thu Nov 10, 2011 1:47 am
by EJ1STYLEN
Can a ej coupe sway bar fit the 4dr eg? Guy on cl selling one of a en coupe for 60 links and all.
PostPosted: Thu Nov 10, 2011 6:07 am
by Greasedmonkey
yes
PostPosted: Mon Nov 21, 2011 7:41 am
by JohnRM
I'm about to get both front and rear 94 LS swaybars. Would I also need the 94 LS integra endlinks and LCA's?
This is going into a 93 EG sedan :D
