Swapping suspension from Del sol to Coupe
Postby OmarG » Sat Jan 29, 2011 12:14 am
I'm going to attempt to swap the front and rear suspension off of my B16 del sol onto my coupe. I have KYB AGX's and Skunk2 coilovers. I wanted to swap the entire setup onto my coupe, including the Sel sol's rear disk brakes. How is the swap going to be different from this?
http://civic-eg.com/viewtopic.php?t=4129
I also wanted to swap the front hub assemblies as well, since the ones on my coupe have bad wheel bearings. PULEEEEEEAAAASE help. I've never attempted suspension work on my own before. The most I've done is swap axles. (My axle pops out at least twice a week on my type r swap.)
I also would like to swap the del sol's larger sway bars too. I miss the way the del sol handled.
OmarG
Who wants a moustache ride?
Postby Ajax1989 » Sat Jan 29, 2011 1:38 am
everything should swap over with ease
i did a whole rear suspension swap off a DA teggy to me eg
and everything bolted up
just u gotta pull the ebrake cables outta the sol :thumb:
Ajax1989
Nissan Primera
Nissan Primera
Postby Ecc0 » Sat Jan 29, 2011 2:54 pm
You'll need the handbrake / E brake cable from either a EG8 or Teg as the chassis lengths are different so Sol ones won't fit.
Everything else is cosha :thumb:
Built not bought - New build post is here!!!
http://www.civic-eg.com/viewtopic.php?t=19419
Ecc0
Jr. Member
Jr. Member
Postby OmarG » Sun Jan 30, 2011 5:39 am
I decided not to do the brakes. I swapped out the just rear suspension instead. I need to swap the front hub assembly on the passenger side, but I can't break the ball joints to break free on it even when I pound on it. do I NEED to buy a pickle fork for them?
OmarG
Return to EG Chassis Suspension
Who is online
Users browsing this forum: No registered users and 1 guest
