- Fri Nov 14, 2008 3:23 pm
#78615
Ok so i have a Kenwood 12" and a Jensen 600watt amp in my car, all was working fine for the longest time, then about 2 to 3 weeks ago it stopped working, it gets power, and if i turn the car off the sub makes a pop noise, if i drive the car for a while, about half an hour to 45 minutes the sub will just magically come on and work again.
i've checked the wiring, even replaced wires that looks like they were overly worn, ground is good, and the amp lights up and shows the power indicator is on as well. yet there is no sound from the sub, if i remove the wire from the connection while the stereo is on, it causes static in the sub, so i know that is getting signal, just no sound...
Any thoughts or input?
Remember when Civics were cool ? Yea me neither
