By youngrizzy1989
#345597 Hello,
So I installed a autppage rf425 in my 94 ex sedan I got everything to work as in the lights to flash Starter kill to work. ... everything besides the locksI tried to wire them to the 2 wire plug behind the fuse boxI even went straight to the door lock switch.. and still nothing and my locks work perfectly fine
my buddy has the same alarm in his si hatch wired up the same way that mine is and his locks work
and thanks ai advance :x [/code]
By ExCoupe94
#345725 If u have the correct wires for lock and unlock simply grounding one or the other will fire the actuator... pretty easy to test if u tagged the correct wires.
On that autopage alarm make sure u connect violet and violet/red on the lock harness to ground and blue and green are connected to the two tagged wires in the civic the violet wires should already be wired together with a fuse.
