ECU, Wiring, Sensors
By 92egdxhatch
#199841 im removing heat/ac/defrost what do i do about the coolant lines for the heater core?
92egdxhatch wrote:im removing heat/ac/defrost what do i do about the coolant lines for the heater core?
get one of these
and hook the coolant hoses together
we did this when my heater core went out on my ranger back in the day :thumb:
By 92egdxhatch
#199846 where can i get one?
#199849 auto zone, kargens, your local auto part store
or home depo, lowes.. it just a universal hose connector type thing :thumb:
By 92egdxhatch
#199975 okay i want to move my battery into the interior, id like to put it under the dash do you guys have any suggestions?
By turbosedan717
#206759 hey man the car looks amazing. and i've been following the tuck on my eg sedan all the way but i've hit a bit of a snag. i was wondering if there's any way to do a good tuck like this without removing the heater core? and if so where in the firewall should i run my wires?
By hooplin
#206805 hey teal another heater related question. My heater is gone can i remove the hose and plug them up. Or do i have to loop them?
By hatchie
#212419 hola quick questions por favor
- can you take out the heater core etc and run the wires through that hole
but still run a.c?
-you dont have windshield washers anymore do you?
-for a mild tuck can you just strip the harness to the headlights away from the drivers side and keep the plug ins sitting on the strut tower?
-when i tuck the passenger side headlight harness do i have to remove the fuse box and the battery, and anything i should be aware of as far as problems or key tips?
-oh and when you remove the cowel .... is there an easy way to pop the clips off..... i just dont wanna break my minty ones
turbosedan717 wrote:hey man the car looks amazing. and i've been following the tuck on my eg sedan all the way but i've hit a bit of a snag. i was wondering if there's any way to do a good tuck like this without removing the heater core? and if so where in the firewall should i run my wires?
I have not seen this done. If it is possible, it would be extremely difficult because everything will be so compact behind the dash.
hooplin wrote:hey teal another heater related question. My heater is gone can i remove the hose and plug them up. Or do i have to loop them?
You can block them or loop them :thumb:
hatchie wrote:hola quick questions por favor
but still run a.c?
I'm not sure how the AC runs, my car didn't have it.
I don't have a wiper motor in the car right now, but I extended the harness for when I put it back in. Technically I don't think my car is street legal w/o wipers, even though I have rain-x.
Absolutely :thumb: A lot of people do a partial tuck this way.
I did mine as a full tuck, so I had to. I am unsure about partial tucks. Some members have done partial tucks on here but I cant recall about the battery or fuse box.
Those clips are a bitch... I found that if I grabbed them with pliers and rotated them 90°, then they pop out easily.
By hatchie
#212499 ok sense you said you dont have wipers anymore......where u gunna put the resevior when you put it back in?? cuz now your batterys in the way
By turbosedan717
#214133 okay if anyone can help it'd be greatly appreciated. so i have my chassis harness tucked and everything squared away. or so i thought. i hook up my battery and only my driver side electronics are working? i am completely lost by this because everything on the driver side works fine and NOTHING on the passenger side works. please help asap!
By littleman
#214145 teal, that tube with a red cap pointing 11 o'clock in the IM, ever tried rotating it so it points downwards so i can cut the hose going to booster shorter :?
