ECU, Wiring, Sensors
By Tino
#339340 on the driver side when you pulled the harness through the fire wall you know how you have the plugs for the motor? when you reinstalled the harness where did you put those few plugs at??
im stuck on mine lol
By Tino
#339351 Oh okay. That help a lot.
Thanks bro!
By PURPLE_B16
#345576 very helpful been working on mine for awhile now lol
do i need to extend the alternator power wire to the fuse box?
#345581 If you're moving the fuse box further away than you will probably have to. I got new wire anyways just because the stock wire is old and hard to work with.
By PURPLE_B16
#345600 NOW THE PLUGS THAT GO TO THE DRIVERSIDE AND PASSENGER SIDE THAT THE ENGINE HARNESS CONNECTS TOO THE MEET UNDER THE DASH AFTER U PULL THEM THRU CORRECT ???
