P28 OBD-1 ECU Civic / Integra Pinout Diagram
Mon Sep 15, 2008 6:50 pm
by Greasedmonkey
Sun Sep 28, 2008 6:47 am
by Greasedmonkey
Can someone make this a sticky? Im not sure how to do it.
Sun Sep 28, 2008 8:16 am
by ohDirka
Greasedmonkey wrote:Can someone make this a sticky? Im not sure how to do it.
Done
Sun Sep 28, 2008 5:25 pm
by Greasedmonkey
Much Thanks! I couldnt figure out how to do that. I guess I cant.
Fri Apr 17, 2009 3:00 am
by suspendedHatch
One small correction. It says "all VX's use 5 wire O2's". This isn't true. The 92 CA model VX and all 92-95 model VXs are 5 wire O2. However, 93-95 CA model VX's use a standard 4 wire O2.
How do you know if your car is California or federal? Read your emissions label (the sticker on the underside of the hood). It will say "this vehicle conforms to ________ model year standards" or something very close to that. And if that sticker is missing then you will have to interpret your VIN... on the other hand, just count the damn wires on your O2 sensor!
Wed Apr 18, 2012 7:05 am
by KOTIHUN
Hello there.
There is a small problem.
P28 ECU D16Z6 ESI
Specify what to do with the cel code?
20 and 40, A 20 What is happening? Water and tear.?
And what is 40?
The engine is not running.
AC does not load, main relay clicks ..
I do not speak English.google turns
obd2a to obd1 or obd2b to obd1?
Sat Aug 25, 2012 9:06 am
by egcivic117
i have a 92 eg and just got a p28 with hondata wich harnes do i need to get a obd2a to obd1 or obd2b to obd1?
