Need someone to verify this will work
Posted: Mon May 23, 2016 11:47 am
http://civic-eg.com/forum/
Gram0401 wrote:I'm moving the battery out from under the hood and I just need someone to verify that the way the alternator is wired will work… if there is anything you would change let me know… thanks
Driv-it-hard wrote:Gram0401 wrote:I'm moving the battery out from under the hood and I just need someone to verify that the way the alternator is wired will work… if there is anything you would change let me know… thanks
Everything looks good.
I have a question about the jumper 2 gauge going one fire plug to the other. I think it would be better and less stuff on the fire wall to add a distribution block for Alt ,Starter and power to fuse box. I all would think about a thinner wire going to fuse box. 2 Gauge would be a over kill. You would be fine on a 8 or 6 gauge.
Just for thought.
Nice setup tho.
