ECU, Wiring, Sensors
By rich6972
#352802 Check for a loose ground wiire. If you tap the side of the dash does the lights flicker at all.
By rich6972
#352803 Also check the dash dimmer switch. Could be at fault.
By rich6972
#352804 Check for a loose groumd wire. If you tap the side of the dash does the lights flicker at all.
By TrailerTrash
#352805 probably the dimmer switch
By J-rodSmitty
#352807 Thanks guys ill check on that today!
By TrailerTrash
#352820 you may not be able to tell if its bad without swapping it out with one that you are 100% sure works
