Help with starting and running issue
Posted: Tue Jan 14, 2014 1:19 am
Here is the problem. Normally when you turn the key to the on position the check engine light and oil pressure light will come on and you can hear the relay for the fuel pump, then you turn the key to start and the engine turns over and then starts running.
lately I have an intermittent issue where when you turn the key on the check engine light does not come on turn to start and it turns over but does not start. I have even been driving and the engine quits and I have to pull over shut the ignition off and restart the car. Could this be a bad relay in the power to the ECU or is my ECU about die?
Thanks in advance for any help.
